Adding the HSM200 to your Z-Wave Network (for non-HomeSeer systems)
The HSM200 is a Z-Wave certified multi-sensor that should work with any Z-Wave certified system controller. Please follow the procedure required by your controller manufacturer for including the HSM200 with your Z-Wave network.
Note: The Color Control will only work if your control system supports the Z-Wave Color Command Class. Please check with the manufacturer of your system to verify compatibility.
