Removing the HSM200 from your Z-Wave Network (for HomeSeer HS3 System Users)
Should you need to remove or reset your HSM200 to its factory configuration, please follow this procedure:
  1. Open the PLUG-INS drop menu, then Z-Wave, then select Controller Management
  2. Expand your Z-Wave controller.
  3. Open the Actions menu and select Remove / Exclude Z-Wave Device.
  4. Click Start to initiate the Remove process and press the button once on the side of the HSM200 to put it into Exclusion mode. The process should take very little time to complete.
