How to Schedule Door Lock User Codes
With HS3, you can enable ("set") and disable ("remove") door lock user codes with events. This is particularly handy for scheduling access for house cleaners and other regular unattended visitors or guests. The example below includes two events: one for setting the user code and one for removing the user code. Each event is triggered by a time and a day.
