Companion Operation
Your new HomeSeer switch may only be operated locally (manually) with the following operations:
  • Press (tap) the top of the paddle to power the load (works with HS-WD100+ or HS-WS100+).
  • Press (tap) the bottom of the paddle to cut power to load (works with HS-WD100+ or HS-WS100+).
  • Press & hold the top or bottom of the paddle increase or decrease the dim level of the load (works with HS-WD100+ only).
