Web Access
Once the unit boots, you’ll need to access the web interface to set the system up. The method below should work with any web-enabled device. (We recommend using Google Chrome.)
  1. Go to http://find.homeseer.com.
  2. Click Search....
  3. Your HomeSeer system should now appear at the bottom. Click the IP address hyperlink to access your system’s web interface.
