Network Backup/Restore
Back-up Your Z-Wave Network
  1. In the web interface, open the PLUG-INS drop menu, then Z-Wave, then select Controller Management. Expand the listing for your interface and select Back Up this interface from the Actions menu.
  2. Rename the backup file (if desired) and click the START button. The operation should only take a few seconds and the word “Done” will appear when complete. Note the name of this file for later.
Restore Your Z-Wave Network
  1. In the web interface, open the PLUG-INS drop menu, then Z-Wave, then select Controller Management. Expand the listing for your interface and select Restore a Network to this Interface from the Actions menu. menu.
  2. Click the Choose A File drop menu and select the network you wish to restore.
  3. Click Confirm once you are ready to begin the restoration.
  4. Once your restoration is finished, you will need to run a Test Node Connectivity test from the same Actions menu.
If you are upgrading from a Z-Stick or Z-Troller,  click here for video instructions!
