Wall Switch Operation
Your new HomeSeer switch may be operated locally (manually) or remotely using a Z-Wave compatible controller or home automation system.
Local Control:
  • Press (tap) the top of the paddle to power the load.
  • Press (tap) the bottom of the paddle to cut power to the load.
Remote Control:
  • On / Off control is available remotely. Consult your controller manual for details.
    HomeSeer users: this switch creates 3 devices: a root device, central scene device and control device. The root device may be used to manage Z-Wave settings. The central scene device may be used as a trigger for events. The control device will send on / off commands to the switch.
