Configuring SEL Wi-Fi
Wi-Fi is included with your SEL. Follow these instructions for setting it up (you must have HS set up with the Ethernet cable first, and a monitor and keyboard are necessary).
Once logged in to your SEL:
  1. Click on the two arrows in the bottom right hand corner.
  2. Select your Wi-Fi SSID and enter your password.
