Removing Z-Wave Devices
Follow the procedure below to reset a device to its factory settings or remove the device from your Z-Wave interface.
  1. In the web interface, open the PLUG-INS drop menu, then Z-Wave, then click on Controller Management.
  2. Locate the Z-Wave Interfaces area and expand your Z-Wave Controller section. Open the Actions menu and choose Remove/Exclude a Node
  3. Click the Start button. Your Hometroller is now in Add mode and is ready to communicate with your device.
  4. Activate the network button (or button sequence) on your device and observe the adding process in the green log window. When done, you'll receive an acknowledgement such as "DONE - Remove Node Operation is Complete." Your Z-Wave device is now removed from your Z-Wave network!
