System Backup/Restore
This procedure will backup Device Information, Events, and HS3 settings. If you follow the Z-Wave Network Backup/Restore procedure first, that data will be included in this backup.
Backup HS3 Configuration
1. Navigate to Tools > Setup
2. Locate the Configuration section
3. Select Backup Config. Select a location to save the zip file.
A zip file will be stored locally on the computer you are accessing HS3 with. If you performed the network backup/restore prior to this, that file will be included.
Restore HS3 Configuration
3. Select Restore Config
4. Locate the Zip file saved from the Backup HS3 Configuration procedure. This may take a few minutes and your system will restart upon successful restore.
Note: You may need to re-register your system due to IP address changes. If you have any issues, please contact support@homeseer.com or call us at 603-471-2816.
See Z-Wave Network Backup/Restore to restore your Z-Wave nodes to a new Z-Wave interface.
