Power Failure Control
Q: Does the HS-WD100/200 or HS-WS100/200 support the configuration parameter that would let the user control what state the dimmer/switch is in after a power failure so the unit either returns to the power state before the outage or can have them default to always restore to Off state when power is restored?
A: Currently, there’s no specific parameter setting for this. The dimmer and switch will power on to their previous state when power is restored.
