Dashboard: Moving a Widget
On Android:
To move a widget, long-press until you feel haptic feedback or see a menu. Once either of these actions occur, the widget can be moved. See below for what you will see when moving.
Keep in mind that the correct amount of space is required to move a widget up, down, left, or right.
On IOS:
Long press on a widget, it will move when its ready to be moved.
You can drag the widget to a new location. Other widgets will automatically move to fill in empty space.
