Moving a Widget
On Android:
To move a widget, long-press until you feel haptic feedback or see a menu. Once either of these actions occur, the widget can be moved. See below for what you will see when moving.
Keep in mind that the correct amount of space is required to move a widget up, down, left, or right. The widget you are moving will not displace other widgets to make room for itself.
On iOS:
To move a widget, long-press on its name, and you will feel haptic feedback on your phone when the widget is ready to be moved.
Other widgets will automatically move to fill in empty space. Widgets will fill the screen left to right and will not leave open space.
Still need help? Try Searching or Contact Us Contact Us
