Cameras: Add Widget to Dashboard
Navigate to your Camera screen.
On Android:
Long press on the camera being added to the Dashboard.
When the menu pops up, select Add to Dashboard.
A New Dashboard Widget screen will pop up. There the Dashboard can be chosen and the ability to rename the Widget.
On IOS:
Tap a camera view, the camera view displays. Click on the "+" in the upper right corner to open the New Dashboard Widget screen.
To rename the widget, click on the name under the camera. You can also hide the name if desired.
Note: Camera widgets will update every 5 seconds.
