Delete a Dashboard
On Android:
While in the Dashboard section of the app, tap the three-dot menu in the top right corner of the screen. You will see a menu appear, and the third option will be Delete Dashboard. You will then be asked if you are sure you want to delete it, as the widgets here will be irreversibly deleted.
On iOS:
While in the Dashboard section of the app, tap the three-dot menu in the top right corner of the screen. You will see a menu appear, and the last option will be Delete Dashboard. You will then be asked if you are sure you want to delete it, as the widgets here will be irreversibly deleted.
Still need help? Try Searching or Contact Us Contact Us
