Android Change Log
v1.1.3 Release Notes
Published 7/1/20
Changes
  • Update device type identification for HS4 types
  • Replace text referencing "HS3" with "HomeSeer"
v1.1.2 Release Notes
Published 6/5/20
Changes
  • Fix remote connections to plugin and recording pages
  • Manage events through the "Manage Events" menu action on the Events page
  • Fix a bug when loading cameras that prevents them from loading
  • Other minor updates
v1.1.1 Release Notes
Published 2/21/20
Changes
  • [HSM-786] - View camera recordings page for HS4 systems
  • [HSM-787] - Manage plugins page for HS4 systems
  • [HSM-788] - Update brand colors used in app
Bugs Fixed
  • [HSM-803] - Selecting a color from the picker crashes Android app
v1.1.0 Release Notes
Published 8/12/19
Changes
  • [HSM-755] - New HomeSeer Camera Inclusion Process Guide
Bugs Fixed
  • [HSM-587] - HTTPS communication via IP over LAN is not allowed
  • [HSM-381] - Unexpected network error while trying to login
    • Error message content has been expanded on to provide more context about the specifics of the network issues.
  • [HSM-233] - System version compatibility checks interrupt use
Bugs Fixed
  • [HSM-496] Some Dashboard locations are still unavailable after moving a widget out of that spot
  • [HSM-388] Landscape orientation is not yet supported on the camera details page
  • [HSM-387] Scrolling while dragging to move a widget is not yet supported
v1.0.6 Release Notes
Published 4/9/19
Changes
  • [HSM-697] Automatically navigate to the device list when connecting to a session that has no widgets
  • [HSM-699] - Back button no longer immediately closes the app on the main page
Bugs Fixed
  • [HSM-495] Plugin devices missing in HomeSeer Mobile but showing up in HSTouch
    • A new plug-in developer document was published that outlines the recommended way to configure devices so they show up in HomeSeer Mobile
  • [HSM-541] Application will sometimes crash when switching tabs
  • [HSM-626] Dashboard tab is always selected after switching systems
  • [HSM-652] Login page logo vector data causes some Lollipop devices to crash
Known Issues
  • [HSM-381] Unexpected network error while trying to login
    • More details will now be available on error messages to aid troubleshooting
v1.0.5 Release Notes
Published 2/25/19
Bugs Fixed:
  • [HSM-643] - App crashes when resuming from a background state when the last page is not the main activity
Known Issues:
v1.0.4 Release Notes
Published 2/18/19
Changes:
  • [HSM-489] - Register with MyHS button added to Login page
  • [HSM-490] - HomeSeer.com Link added to system menu
  • [HSM-590] - Login & Help page update
  • [HSM-594] - Link to MyHS account management added to system menu
  • [HSM-595] - Link to HomeSeer shop added to system menu
  • [HSM-597] - Voice commands speak their responses
Bugs Fixed:
  • [HSM-554] - Confirm to Control is not being honored for some devices
  • [HSM-596] - Dashboard tab is always selected when returning to the app from a background state
  • [HSM-605] - Object reference error when the default system is offline
Known Issues:
v1.0.3 Release Notes
Published 2/12/19
Bugs fixed:
  • [HSM-385] App not respecting some timezone and clock configurations
  • [HSM-386] User is logged out when opening the app from the background even though Remember Me is checked
  • [HSM-488] Dashboards are lost when logging in with a username with different case letters
  • [HSM-492] Some right to left configurations are causing the app to crash
  • [HSM-494] App not sending users to the login screen when the session has expired
Known Issues
v1.0.2 Release Notes
Published 2/8/19
Bugs fixed:
  • [HSM-328] - Crash when a data adapter is disposed during an update notification
  • [HSM-331] - Crash when receiving updates from HS3 while switching dashboards
  • [HSM-332] - Application crashes when opening the Create/Edit Widget page with a null device bundle
  • [HSM-336] - Application crashes when resuming from a background state
  • [HSM-337] - Crash when editing a thermostat widget
  • [HSM-339] - Camera snapshot request stack is null when a task starts to download a snapshot
  • [HSM-348] - App crashes when editing a widget that does not have a valid reference
  • [HSM-349] - Crash on the device list when trying to update a specific device while the whole list is being refreshed
  • [HSM-353] - Crash while renaming a dashboard
  • [HSM-356] - Unable to load the device list because of a slider range value offset
  • [HSM-357] - Some network calls are orphaned on older OS versions
  • [HSM-358] - Navigation header gradient is reversed
Known Issues
v1.0.1 Release Notes
Published 2/5/19
  • Increased the resolution of the HomeSeer logo to mitigate blur caused when scaling it to fit larger screens
  • Improved the stability of the dashboard page
Known Issues:
  • Scrolling while dragging to move a widget is not yet supported
  • Images are slow to load on some older devices
  • Landscape orientation is not yet supported on the camera details page
v1.0 Release Notes
  • 2/1/19: Initial release
Known Issues:
Still need help? Try Searching or Contact Us Contact Us
