Adding or Removing Devices to/from Google Home
If you add or remove devices from your HomeSeer system, you’ll need to unlink and re-link your system to update your device list.
  1. Launch the Google Home app and access the “hamburger menu” in the top left corner. Select “Home control”.
  2. Click the “+” button at the bottom of the next screen to add devices and then select “HomeSeer” from the list that pops up. This will UNLINK your system.
  3. Now select HomeSeer from the Home control list. Our MyHS log in screen will now appear. Enter your MyHS credentials and click LOGIN. Google Home will now link to your HomeSeer system and recreate your device list.
