Connecting with HS3Touch through MyHS
Configuring HS3Touch Mobile App with MyHS
Please note! Unless you have HS3Touch Designer and have created a custom interface, you will want to use our new app, HomeSeer Mobile instead.
HS3Touch Android:
  1. Download and install the HS3Touch mobile app from the Google Play store.
  2. Launch HS3Touch and choose Settings from the three dot ( ⋮ ) menu.
  3. Tap MyHomeSeer and enter your MyHS username and password.
  4. Launch HS3Touch and choose MyHomeSeer if prompted to select a connection method.
HS3Touch iOS (Apple):
  1. Download and install the HS3Touch mobile app from the Apple App store.
  2. Access the Settings app in your device and open the HS3Touch settings.
  3. Tap MyHS, then enter your username and password.
