How To Add HS-FS100+ to SmartThings Hub
Go to this URL and log in with SmartThings account:  https://graph-na04-useast2.api.smartthings.com
Important:This sensor must be added to your SmartThings hub “non-securely”. Please refer to the HomeSeer user guide for more information regarding this.
Click on the "My Device Handlers" menu
Click "Create New Device Handler" on the right
Click "From Code"
Click here to view the code or see the snippet below
Click "Create" at the bottom
Click "Publish" and select "For Me"
 *  HS-FS100+
 *  Original Author:
 *    Kevin LaFramboise (krlaframboise)
 *  Modified by HomeSeer for HS-FS100+ Flex Sensor
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * Version 1.1 2/25/19
metadata {
	definition (
		name: "HomeSeer Flex Sensor",
		namespace: "HomeSeer",
		author: "support@homeseer.com"
		capability "Sensor"
		capability "Battery"
		capability "Configuration"
		capability "Refresh"
		capability "Health Check"
        capability "Temperature Measurement"
		attribute "lastCheckin", "string"
		fingerprint mfr:"000C", prod:"0202", model:"0001"
	simulator { }
	preferences {
		input "tempReporting", "enum",
			title: "Temperature Reporting Interval:",
			defaultValue: tempReportingSetting,
			required: false,
			displayDuringSetup: false,
			options: tempReportingOptions.collect { it.name }
        input "lightSensitivity", "enum",
			title: "Light Sensitivity (with light cable):",
			defaultValue: lightSensitivitySetting,
			required: false,
			options: lightSensitivityOptions.collect { it.name }
        input "notificationBuzzer", "enum",
			title: "Notification Buzzer:",
			defaultValue: notificationBuzzerSetting,
			required: false,
			options: notificationBuzzerOptions.collect { it.name }
        input "lightDetectionDelay", "enum",
			title: "Light Detection Delay (detect blinking):",
			defaultValue: lightDetectionDelaySetting,
			required: false,
			options: lightDetectionDelayOptions.collect { it.name }
        input "waterDetectionBuzzerFrequency", "enum",
			title: "Water Detection Buzzer Frequency (with water cable):",
			defaultValue: waterDetectionBuzzerFrequencySetting,
			required: false,
			options: waterDetectionBuzzerFrequencyOptions.collect { it.name }
	tiles(scale: 2) {
		multiAttributeTile(name:"light", type: "generic", width: 6, height: 4, canChangeIcon: false){
			tileAttribute ("device.light", key: "PRIMARY_CONTROL") {
				attributeState "nolight",
					label:'No Light',
					icon: "st.illuminance.illuminance.dark",
					backgroundColor:"#ffffff"
               attributeState "colorchange",
					label:'Color Change',
					icon:"st.illuminance.illuminance.light",
					backgroundColor:"#9ffda1"
				attributeState "light",
					label:'Light',
					icon:"st.illuminance.illuminance.bright",
					backgroundColor:"#33ff3b"
                attributeState "nowater",
					label:'No Water',
					icon: "st.alarm.water.dry",
				attributeState "water",
					label:'Water',
					icon:"st.alarm.water.wet",
					backgroundColor:"#00a0dc"
		valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
			state "temperature", label:'${currentValue}',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
		standardTile("refresh", "device.refresh", width: 2, height: 2) {
			state "refresh", label:'Refresh', action: "refresh", icon:"st.secondary.refresh-icon"
		valueTile("battery", "device.battery", decoration: "flat", width: 2, height: 2){
			state "battery", label:'${currentValue}% battery', unit:""
		main "light"
		details(["light", "water", "temperature", "refresh", "battery"])
// Sets flag so that configuration is updated the next time it wakes up.
def updated() {
	// This method always gets called twice when preferences are saved.
	if (!isDuplicateCommand(state.lastUpdated, 3000)) {
		state.lastUpdated = new Date().time
		logTrace "updated()"
		logForceWakeupMessage "The configuration will be updated the next time the device wakes up."
		state.pendingChanges = true
// Initializes the device state when paired and updates the device's configuration.
def configure() {
	logTrace "configure()"
	def cmds = []
	def refreshAll = (!state.isConfigured || state.pendingRefresh || !settings?.ledEnabled)
	if (!state.isConfigured) {
		//logTrace "Waiting 1 second because this is the first time being configured"
		sendEvent(getEventMap("light", "nolight", false))
		//cmds << "delay 1000"
	configData.sort { it.paramNum }.each {
		cmds += updateConfigVal(it.paramNum, it.size, it.value, refreshAll)
	if (!cmds) {
		state.pendingChanges = false
	if (refreshAll || canReportBattery()) {
		cmds << batteryGetCmd()
	//initializeCheckin()
	//cmds << wakeUpIntervalSetCmd(checkinIntervalSettingMinutes)
	if (cmds) {
		logDebug "Sending configuration to device."
		return delayBetween(cmds, 1000)
	else {
		return cmds
private updateConfigVal(paramNum, paramSize, val, refreshAll) {
	def result = []
	def configVal = state["configVal${paramNum}"]
	if (refreshAll || (configVal != val)) {
		result << configSetCmd(paramNum, paramSize, val)
		result << configGetCmd(paramNum)
	return result
private initializeCheckin() {
	// Set the Health Check interval so that it can be skipped once plus 2 minutes.
	def checkInterval = ((checkinIntervalSettingMinutes * 2 * 60) + (2 * 60))
	sendEvent(name: "checkInterval", value: checkInterval, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
// Required for HealthCheck Capability, but doesn't actually do anything because this device sleeps.
def ping() {
	logDebug "ping()"
// Forces the configuration to be resent to the device the next time it wakes up.
def refresh() {
	logForceWakeupMessage "The sensor data will be refreshed the next time the device wakes up."
	state.pendingRefresh = true
    configure()
private logForceWakeupMessage(msg) {
	logDebug "${msg}  You can force the device to wake up immediately by removing and re-inserting the battery."
// Processes messages received from device.
def parse(String description) {
	def result = []
    logTrace "parse description: $description"
	sendEvent(name: "lastCheckin", value: convertToLocalTimeString(new Date()), displayed: false, isStateChange: true)
	def cmd = zwave.parse(description, commandClassVersions)
	if (cmd) {
		result += zwaveEvent(cmd)
	else {
		logDebug "Unable to parse description: $description"
	return result
private getCommandClassVersions() {
		0x30: 2,	// Sensor Binary
        0x25: 1,    // switch binary
		0x31: 5,	// Sensor Multilevel
		0x59: 1,  // AssociationGrpInfo
		0x5A: 1,  // DeviceResetLocally
		0x5E: 2,  // ZwaveplusInfo
		0x70: 1,  // Configuration
		0x71: 3,  // Notification v3
		0x72: 2,  // ManufacturerSpecific
		0x73: 1,  // Powerlevel
		0x80: 1,  // Battery
		0x84: 2,  // WakeUp
		0x85: 2,  // Association
		0x86: 1		// Version (2)
// Updates devices configuration, requests battery report, and/or creates last checkin event.
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd)
	def result = []
	if (state.pendingChanges != false) {
		result += configure()
	else if (state.pendingRefresh || canReportBattery()) {
		result << batteryGetCmd()
	else {
		logTrace "Skipping battery check because it was already checked within the last ${batteryReportingIntervalSetting}."
	//if (result) {
	//	result << "delay 2000"
	result << wakeUpNoMoreInfoCmd()
	return sendResponse(result)
private sendResponse(cmds) {
	logTrace "sendResponse $cmds"
	def actions = []
	cmds?.each { cmd ->
		actions << new physicalgraph.device.HubAction(cmd)
	sendHubCommand(actions)
	return []
// Creates the event for the battery level.
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
	logTrace "BatteryReport: $cmd"
	def val = (cmd.batteryLevel == 0xFF ? 1 : cmd.batteryLevel)
	if (val > 100) {
		val = 100
	state.lastBatteryReport = new Date().time
	logDebug "Battery ${val}%"
		createEvent(getEventMap("battery", val, null, null, "%"))
// Stores the configuration values so that it only updates them when they've changed or a refresh was requested.
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
	def name = configData.find { it.paramNum == cmd.parameterNumber }?.name
	if (name) {
		def val = hexToInt(cmd.configurationValue, cmd.size)
		logDebug "${name} = ${val}"
		state."configVal${cmd.parameterNumber}" = val
	else {
		logDebug "Parameter ${cmd.parameterNumber}: ${cmd.configurationValue}"
	state.isConfigured = true
	state.pendingRefresh = false
	return []
// Creates water events.
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd) {
	def result = []
	logTrace "NotificationReport: $cmd"
    if (cmd.notificationType == 0x5) {
    	// water
        switch (cmd.event) {
        	case 0:
				logDebug "Sensor No Water"
				result << createEvent(getEventMap("light", "nowater"))
				break
            case 2:
				logDebug "Sensor Detects Water"
				result << createEvent(getEventMap("light", "water"))
				break
	if (cmd.notificationType == 0x14) {
			case 0:
				logDebug "Sensor No Light"
				result << createEvent(getEventMap("light", "nolight"))
				break
			case 1:
				logDebug "Sensor Detects Light"
				result << createEvent(getEventMap("light", "light"))
				break
            case 2:
				logDebug "Sensor Detects Color Change"
				result << createEvent(getEventMap("light", "colorchange"))
				break
			default:
				logDebug "Sensor is ${cmd.event}"
	return result
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
	logTrace "SensorMultilevelReport: ${cmd}"
	def result = []
	if (cmd.sensorType == 1) {
		result += handleTemperatureEvent(cmd)
	else {
		logDebug "Unknown Sensor Type: ${cmd}"
	return result
private handleTemperatureEvent(cmd) {
	def result = []
	def cmdScale = cmd.scale == 1 ? "F" : "C"
	def val = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
	if ("$val".endsWith(".")) {
		val = safeToInt("${val}"[0..-2])
	result << createEvent(createEventMap("temperature", val, null, "Temperature ${val}${getTemperatureScale()}", getTemperatureScale()))
	return result
private createEventMap(name, value, displayed=null, desc=null, unit=null) {
	def eventMap = [
		value: value,
		displayed: (displayed == null ? ("${getAttrVal(name)}" != "${value}") : displayed),
		isStateChange: true
	if (unit) {
		eventMap.unit = unit
	if (desc && eventMap.displayed) {
		logDebug desc
		eventMap.descriptionText = "${device.displayName} - ${desc}"
	else {
		logTrace "Creating Event: ${eventMap}"
	return eventMap
private getAttrVal(attrName) {
	try {
		return device?.currentValue("${attrName}")
	catch (ex) {
		logTrace "$ex"
		return null
// Ignoring event because sensor binary events are being handled by notification report.
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
	// logTrace "SensorBinaryReport: $cmd"
	return []
// Logs unexpected events from the device.
def zwaveEvent(physicalgraph.zwave.Command cmd) {
	logDebug "Unhandled Command: $cmd"
	return []
private getEventMap(name, value, displayed=null, desc=null, unit=null) {
	def isStateChange = (device.currentValue(name) != value)
	displayed = (displayed == null ? isStateChange : displayed)
	def eventMap = [
		value: value,
		displayed: displayed,
		isStateChange: isStateChange
	if (desc) {
		eventMap.descriptionText = desc
	if (unit) {
	return eventMap
private wakeUpIntervalSetCmd(minutesVal) {
	state.checkinIntervalMinutes = minutesVal
	logTrace "wakeUpIntervalSetCmd(${minutesVal})"
	return zwave.wakeUpV2.wakeUpIntervalSet(seconds:(minutesVal * 60), nodeid:zwaveHubNodeId).format()
private wakeUpNoMoreInfoCmd() {
	return zwave.wakeUpV2.wakeUpNoMoreInformation().format()
private batteryGetCmd() {
	return zwave.batteryV1.batteryGet().format()
private configGetCmd(paramNum) {
	return zwave.configurationV1.configurationGet(parameterNumber: paramNum).format()
private configSetCmd(paramNum, size, val) {
	return zwave.configurationV1.configurationSet(parameterNumber: paramNum, size: size, scaledConfigurationValue: val).format()
private canReportBattery() {
	def reportEveryMS = (batteryReportingIntervalSettingMinutes * 60 * 1000)
	return (!state.lastBatteryReport || ((new Date().time) - state.lastBatteryReport > reportEveryMS))
// Settings
private getTempReportingSetting() {
	return settings?.tempReporting ?: findDefaultOptionName(tempReportingOptions)
private getLightSensitivitySetting() {
	return settings?.lightSensitivity ?: findDefaultOptionName(lightSensitivityOptions)
private getNotificationBuzzerSetting() {
	return settings?.notificationBuzzer ?: findDefaultOptionName(notificationBuzzerOptions)
private getLightDetectionDelaySetting() {
	return settings?.lightDetectionDelay ?: findDefaultOptionName(lightDetectionDelayOptions)
private getWaterDetectionBuzzerFrequencySetting() {
	return settings?.waterDetectionBuzzerFrequency ?: findDefaultOptionName(waterDetectionBuzzerFrequencyOptions)
// Configuration Parameters
private getConfigData() {
	return [
    	[paramNum: 3, name: "Temperature Reporting Interval", value: convertOptionSettingToInt(tempReportingOptions, tempReportingSetting), size: 1],
        [paramNum: 1, name: "Light Sensitivity (with light cable)", value: convertOptionSettingToInt(lightSensitivityOptions, lightSensitivitySetting), size: 1],
        [paramNum: 4, name: "Notification Buzzer", value: convertOptionSettingToInt(notificationBuzzerOptions, notificationBuzzerSetting), size: 1],
        [paramNum: 5, name: "Light Detection Delay (detect blinking)", value: convertOptionSettingToInt(lightDetectionDelayOptions, lightDetectionDelaySetting), size: 1],
        [paramNum: 2, name: "Water Detectiong Buzzer Frequency (with water cable)", value: convertOptionSettingToInt(WaterDetectionBuzzerFrequencyOptions, WaterDetectionBuzzerFrequencySetting), size: 1]
private getTempReportingOptions() {
		[name: "30 Seconds", value: 30],
        [name: formatDefaultOptionName("1 Minute"), value: 60],
		[name: "3 Minutes", value: 180],
		[name: "4 Minutes", value: 240]
private getLightSensitivityOptions() {
    	[name: formatDefaultOptionName("High"), value: 0],
		[name: "Medium", value: 1],
		[name: "Low", value: 2]
private getNotificationBuzzerOptions() {
		[name: "Disabled", value: 0],
        [name: formatDefaultOptionName("Enabled"), value: 1],
private getLightDetectionDelayOptions() {
        [name: formatDefaultOptionName("0 Seconds"), value: 0],
		[name: "1 Second", value: 1],
		[name: "2 Seconds", value: 2],
        [name: "3 Seconds", value: 3],
        [name: "4 Seconds", value: 4],
        [name: "5 Seconds", value: 5],
        [name: "6 Seconds", value: 6],
        [name: "7 Seconds", value: 7],
        [name: "8 Seconds", value: 8],
        [name: "9 Seconds", value: 9],
        [name: "10 Seconds", value: 10],
        [name: "11 Seconds", value: 11],
        [name: "12 Seconds", value: 12],
        [name: "13 Seconds", value: 13],
        [name: "14 Seconds", value: 14],
        [name: "15 Seconds", value: 15],
        [name: "16 Seconds", value: 16],
        [name: "17 Seconds", value: 17],
        [name: "18 Seconds", value: 18],
        [name: "19 Seconds", value: 19],
        [name: "20 Seconds", value: 20]
private getWaterDetectionBuzzerFrequencyOptions() {
		[name: formatDefaultOptionName("Every 10 Minutes"), value: 10],
		[name: "Every 5 Minutes", value: 5],
        [name: "Every 30 Minutes", value: 30]
private convertOptionSettingToInt(options, settingVal) {
	return safeToInt(options?.find { "${settingVal}" == it.name }?.value, 0)
private formatDefaultOptionName(val) {
	return "${val}${defaultOptionSuffix}"
private findDefaultOptionName(options) {
	def option = options?.find { it.name?.contains("${defaultOptionSuffix}") }
	return option?.name ?: ""
private getDefaultOptionSuffix() {
	return "   (Default)"
private safeToInt(val, defaultVal=-1) {
	return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private safeToDec(val, defaultVal=-1) {
	return "${val}"?.isBigDecimal() ? "${val}".toBigDecimal() : defaultVal
private hexToInt(hex, size) {
	if (size == 2) {
		return hex[1] + (hex[0] * 0x100)
	else {
		return hex[0]
private canCheckin() {
	// Only allow the event to be created once per minute.
	def lastCheckin = device.currentValue("lastCheckin")
	return (!lastCheckin || lastCheckin < (new Date().time - 60000))
private convertToLocalTimeString(dt) {
	def timeZoneId = location?.timeZone?.ID
	if (timeZoneId) {
		return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
	else {
		return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
	!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
	if (settings?.debugOutput || settings?.debugOutput == null) {
		log.debug "$msg"
private logTrace(msg) {
logDebug "$msg"
	// log.trace "$msg"
Still need help? Try Searching or Contact Us Contact Us
