Enabling Camera Autodiscovery
The HS-CAM-I and HS-CAM-O both require camera autodiscovery to be enabled in HS3. Simply navigate to TOOLS > Setup, then click on the Cameras tab. Auto Discover Supported Cameras will be the first option on this page, and it should be checked.
