Event Examples: Light On At Sunset
Events are automation rules in HS4 that allow your home to run without manual intervention from you. Below we will create a simple event to turn a device on at a certain time. For other event ideas, please view the other articles here in the Events section.
  1. Click on the Events tab at the top left of the page, in between Devices and Cameras
  2. If this is a new installation or HomeTroller, you will see the message "No events defined." Click the
