Controlling a Device Based on Two Factors
It is possible to create events which activate based on more than one trigger or condition. Each event must have a trigger, but conditions are optional, additional qualifiers that can only be used when a trigger has already been set. The difference between the two will be explained in the steps below.
    Still need help? Try Searching or Contact Us Contact Us
