Event Triggers: The Time is...
Time triggers are used to schedule events and may be accessed by selecting The Time Is... from the trigger group menu. Time triggers include the following:
The Time Is This:
Use this trigger to schedule an event for a select a specific time.
The Time Is Sunrise
Use this trigger to schedule an event for sunrise.
The Time Is This Before Sunrise
Use this trigger to schedule an event for a specific amount of time before sunrise.
The Time Is This After Sunrise
Use this trigger to schedule an event for a specific amount of time after sunrise.
The Time Is Sunset
Use this trigger to schedule an event for sunset.
The Time Is This Before Sunset
Use this trigger to schedule an event for a specific amount of time before sunset.
The Time Is This After Sunset
Use this trigger to schedule an event for a specific amount of time after sunset.
Note: Sunrise and sunset calculations are based upon the location settings of your HS4 system and the time and time zone settings of your operating system. You can access your HS4 location settings on the General tab in HS4 Setup.
Still need help? Try Searching or Contact Us Contact Us
