Event Triggers: A Device's Value Is...
Device triggers are used to execute events based on the changing value or status of devices. They may be accessed by selecting  A Device's Value Is... from the trigger group menu. Time triggers include the following:
This Device Changes and Becomes...
Use this trigger to execute an event when a device changes from one state to another.
This Device Has Been/For at Least...
This trigger has been deprecated and has been converted to a condition. It remains on this menu for legacy events but it cannot be used to create new events.
This Device Has Been/For Exactly...
Use this trigger to execute an event when a device has been a specific status or value for an exact period of time.
The Device Had its Value Set and is Not Equal to...
Use this trigger to execute an event when a device has been set to something that is not equal to a specific status or value..
The Device Had its Value Set and is Greater Than...
Use this trigger to execute an event when a device has been set to something that is greater than a specific value.
The Device Had its Value Set and is Less Than...
Use this trigger to execute an event when a device has been set to something that is less than a specific value.
The Device Has a Value That Just Changed:
Use this trigger to execute an event when a device's value has just been changed from one thing to another.
The Device Had it's Value Set To...
Use this trigger to execute an event when a device's value has just been set to a specific value.
The Device Just Had it's Value Set or Changed.
Use this trigger to execute an event when a device's value has just been set to anything at all (including the same value).
Still need help? Try Searching or Contact Us Contact Us
