Event Triggers: A Counter's Value is...
These triggers are used to execute events based on the changing value of counters. They may be accessed by selecting A Counter's Value is... from the trigger group menu. Time triggers include the following:
A Counter's Value becomes this:
This trigger will execute an event when a counter is changed to a specific value.
A Counter's Value is this or a Multiple of this:
This trigger will execute an event when a counter becomes a specific value or multiple of that value.
A Counter's Value has Exceeded this:
This trigger will execute an event when a counter has exceeded a specific value.
A Counter's Value has Exceeded this or a Multiple of this:
This trigger will execute an event when a counter has exceeded a specific value or multiple of that value.
A Counter's Value is this Absolute Value:
This trigger will execute an event when a counter is changed to a positive or negative of a specific value.
A Counter's Value is this or a Multiple of this Absolute Value:
This trigger will execute an event when a counter is changed to a positive or negative of a specific value or multiple of that value
A Counter's Value has Exceeded this Absolute Value:
This trigger will execute an event when a counter has exceeded a positive or negative of a specific value.
A Counter's Value has Exceeded this or a Multiple of this Absolute Value:
This trigger will execute an event when a counter has exceeded a positive or negative of a specific value or multiple of that value.
Still need help? Try Searching or Contact Us Contact Us
