Event Triggers: A Timer's Value is...
These triggers are used to execute events based on the changing value of timers. They may be accessed by selecting  A Timer's Value is... from the trigger group menu. Time triggers include the following:
A Timer's Value Becomes...
This trigger will execute an event when a timer reaches a specific value.
A Timer's Value is Less than...
This trigger will execute an event when a timer's value is less than a specific value.
A Timer's Value is More than...
This trigger will execute an event when a timer's value is more than a specific value.
Still need help? Try Searching or Contact Us Contact Us
