Event Triggers: This Event is Manually Triggered
This trigger is used for any event that isn't designed to executed automatically. The trigger may be accessed by selecting  The Event Is Manually Triggered from the trigger group menu.
Manually triggered events may be executed in the following ways:
  • Click the Run Now button from the event list or from within the event settings screen.
  • Use the Run Another Event event action to add a manually triggered event to another event.
  • Use HomeSeer Mobile or HSTouch to run manually triggered events.
Still need help? Try Searching or Contact Us Contact Us
