Event Actions: Play an Audio File
This action is designed to play an audio file over a Windows speaker client of HSTouch Android client when an event is executed. The action may be accessed by selecting Play an Audio File from the action group menu.
Play an Audio File
Click the button next to the File field to open a list of existing audio files or click the other button to the right to upload your own custom audio file. Available speaker clients or HSTouch Android clients are listed below the File field. Select the ones you wish to play the audio file on or leave these unchecked to play the file to all clients. In the example below, the file LG-Aert.wav will play only on the HOMETROLLER:KITCHEN client when the event is executed.
Still need help? Try Searching or Contact Us Contact Us
