Event Actions: Run Another Event
This event action is designed to execute the actions of another event within the current event. The action may be accessed by selecting Run Another Event from the action group menu. Simply select the event you wish to execute and enter a delay time (if desired). An option to Check conditions on target event will only run the target event if those conditions are also satisfied.
Run Another Event
This action is useful for simplifying events that include repetitive actions or sequences. In the example below, the system will speak, then run the event All Lights Off from the Lighting event group. then speak again.
Still need help? Try Searching or Contact Us Contact Us
