Event Actions: Run a Script or Script Command
This event action is designed to execute a custom script of script command within the current event. The action may be accessed by selecting Run a Script or Script Command from the action group menu. Simply select the script (or enter the script command) you wish to execute or build your own script.
In this example, the Startup.vb script will be run when this event executes.
Still need help? Try Searching or Contact Us Contact Us
