What is the difference between the Z-NET or Zee S2 and the Lite models?
The only difference between the Z-Net or Zee S2 and the Z-Net Lite or Zee S2 Lite is that the Lite models do not feature Wi-Fi connectivity out-of-the-box. However, Wi-Fi compatibility can be achieved with this USB Wi-Fi adapter sold separately. We recommend using an ethernet connection when possible for maximum network stability.
