General Setup
General settings for HS4 may be accessed by clicking Setup and then selecting the General tab.
License
Click the REGISTER button to edit or change your license ID and password. This is useful when upgrading a trial license or moving for one edition of HS4 to another.
Configuration
Click the EDIT CONFIG button to manage your system's selected data file.
  • SWITCH: use to switch to another data file
  • NEW: use to create a new data file
  • RENAME: use to rename the selected data file
  • BACKUP/RESTORE: use to backup or restore the selected data file
Location
This setting allows HS4 to calculate sunrise and sunset times for your system. Click the SELECT LOCATION button to select the worldwide location that's closest to your HS4 installation.
Alternately, you may manually enter your longitude and latitude for even greater accuracy.
Other Settings
Save Your Work!
Still need help? Try Searching or Contact Us Contact Us
