Registering HS4
Whether you have purchased a HomeTroller, a full HS4 license, or just have a trial license you will need to register HS4 in order to use it. Registration is a short process, so after a few minutes your setup will be registered and ready to automate!
Connecting to HS4
Regardless of how or where HS4 is running, you can always use find.homeseer.com to connect to it while on the same local network. Once connected, you will be greeted with a registration screen.
Registration
  1. Enter your license ID and password. If you are using a trial or purchased a license from shop.homeseer.com, then your license information will be in an email from licensing@homeseer.com. If you do not have it, check your spam folder or contact us at support@homeseer.com if you cannot find it. If you have a HomeTroller, it is printed on a sticker on the bottom of the controller. Once entered, click Continue.
  2. If your HS4 license is not an upgrade from HS3, then you are all set and will be requested to enter your personal information so that we may verify license ownership should you need technical support.
    If your HS4 license is an upgrade from HS3, you will be prompted to enter your HS3 license information in order to verify that the correct upgrade is being used. Click Continue.
  3.  If you have Amazon Alexa, Google Home, or IFTTT connected to your HS3 setup, step 4 on the registration page will ask if you would like to transfer those configurations to your new HS4 setup. Click Confirm to bring these integrations to your new setup.
  4. Registration is now complete! Click Finish and you will be brought to your new Devices page. Control devices from here or explore the new options and interface.
Still need help? Try Searching or Contact Us Contact Us
