Setting Up MyHS Remote Access
MyHS is a free cloud service that will allow you to access your HomeTroller or custom HS3 installation from anywhere using a browser-enabled device, HomeSeer Mobile, or our
HS3Touch Designer app. The instructions below will walk you through the process of creating your MyHS account.
  1. Go to myhs.homeseer.com/Register.
  2. Enter your desired account credentials and your HS3 license information. This can be found on the bottom of your HomeTroller or here if you purchased a license on shop.homeseer.com.
  3. Once everything is entered, click Register.
  4. You will then receive a verification email. Check your email and click the verification link. If you do not receive the verification email, make sure to check your spam folder. If you still do not have it, contact us here.
    Your MyHS account has now been created and your HomeSeer system can be accessed any time at myhs.homeseer.com! For information on setting up HomeSeer Mobile with your MyHS account, click here. If you have custom interfaces created in HSTouch Designer for use in HS Touch, visit here.
    Account Setup in the HS4 Web Interface
    After creating your account on myhs.homeseer.com, you will want to connect to your HS4 system. From the web interface, click on the Setup tab, then the Users tab. There should already be an account here with the same credentials you used to make your MyHS account above. If this account has not been created, use the Add button to add an account with the same credentials.
    This account must be the Local account and have Admin user rights. These are the second and fifth icons under the User Type in the screenshot above. Mousing over a button will reveal a tool tip with its name if you are unsure.
Still need help? Try Searching or Contact Us Contact Us
