Selecting a Z-Wave Network
Single Network Systems (applies to most systems)
If your HomeSeer system is configured to work with a single Z-Wave interface or if you have multiple Z-Wave interfaces managing a single Z-Wave network, Z-Seer+ will automatically load and scan the devices on your network once it's connected to your system.
Multiple Network Systems
If your HomeSeer system is configured to work with a multiple Z-Wave interfaces managing multiple Z-Wave networks, a Network Selection screen will prompt you to select a network to work with the first time Z-Seer+ connects to your system. If you wish to change networks, you can access the Network Selection screen from the Edit menu as shown below. Note that connection and network settings are saved as part of your layout when you exit Z-Seer+.
