This article will show you how to add a camera widget to your HomeSeer Mobile dashboard.
On Android:
From the Cameras section of the app, you can tap the three-dot menu button in the top right after tapping a camera, which will open a small menu giving you two options to add the device to your dashboard:
You can also long-press the desired camera to see the options above.
On iOS:
From the Cameras section of the app, you can tap on the name of a device, which will bring you to the Device Details page. Here, you can tap the three-dot menu button for a device, which will open a small menu, giving you two options to add the device to your dashboard:
Note: Camera widgets will update every 5 seconds.
