Android release notes for HomeSeer Mobile.
v1.1.13 Release Notes
Published
  • Add an import/export dashboard feature. This feature allows you to generate JSON for an existing dashboard so you can copy its configuration to an empty dashboard.
    1. Go to the dashboard you want to copy
    2. Open the import/export dashboard page
    3. Copy the JSON
    4. Go to an empty dashboard
    5. Open the import/export dashboard page
    6. Paste the JSON into the available text box
    7. Press the import button
  • Remove Firebase analytics. The application size should be significantly reduced.
v1.1.12 Release Notes
Published
Changes
  • Fix an identification issue with thermostats created using the HS4 Ecobee plugin
v1.1.11 Release Notes
Published
Changes
  • Fix a crash on the device list when displaying a certain media device
  • Set version for iOS and Android to match at v1.1.11
v1.1.3 Release Notes
Published
Changes
  • Update device type identification for HS4 types
  • Replace text referencing "HS3" with "HomeSeer"
v1.1.2 Release Notes
Published 6/5/20
Changes
  • Fix remote connections to plugin and recording pages
  • Manage events through the "Manage Events" menu action on the Events page
  • Fix a bug when loading cameras that prevents them from loading
  • Other minor updates
v1.1.1 Release Notes
Published 2/21/20
Changes
  • [HSM-786] - View camera recordings page for HS4 systems
  • [HSM-787] - Manage plugins page for HS4 systems
  • [HSM-788] - Update brand colors used in app
Bugs Fixed
  • [HSM-803] - Selecting a color from the picker crashes Android app
v1.1.0 Release Notes
Published 8/12/19
Changes
  • [HSM-755] - New HomeSeer Camera Inclusion Process Guide
Bugs Fixed
  • [HSM-587] - HTTPS communication via IP over LAN is not allowed
  • [HSM-381] - Unexpected network error while trying to login
    • Error message content has been expanded on to provide more context about the specifics of the network issues.
  • [HSM-233] - System version compatibility checks interrupt use
Bugs Fixed
  • [HSM-496] Some Dashboard locations are still unavailable after moving a widget out of that spot
  • [HSM-388] Landscape orientation is not yet supported on the camera details page
  • [HSM-387] Scrolling while dragging to move a widget is not yet supported
v1.0.6 Release Notes
Published 4/9/19
Changes
  • [HSM-697] Automatically navigate to the device list when connecting to a session that has no widgets
  • [HSM-699] - Back button no longer immediately closes the app on the main page
Bugs Fixed
  • [HSM-495] Plugin devices missing in HomeSeer Mobile but showing up in HSTouch
    • A new plug-in developer document was published that outlines the recommended way to configure devices so they show up in HomeSeer Mobile
  • [HSM-541] Application will sometimes crash when switching tabs
  • [HSM-626] Dashboard tab is always selected after switching systems
  • [HSM-652] Login page logo vector data causes some Lollipop devices to crash
Known Issues
  • [HSM-381] Unexpected network error while trying to login
    • More details will now be available on error messages to aid troubleshooting
v1.0.5 Release Notes
Published 2/25/19
Bugs Fixed:
  • [HSM-643] - App crashes when resuming from a background state when the last page is not the main activity
Known Issues:
v1.0.4 Release Notes
Published 2/18/19
Changes:
  • [HSM-489] - Register with MyHS button added to Login page
  • [HSM-490] - HomeSeer.com Link added to system menu
  • [HSM-590] - Login & Help page update
  • [HSM-594] - Link to MyHS account management added to system menu
  • [HSM-595] - Link to HomeSeer shop added to system menu
  • [HSM-597] - Voice commands speak their responses
Bugs Fixed:
  • [HSM-554] - Confirm to Control is not being honored for some devices
  • [HSM-596] - Dashboard tab is always selected when returning to the app from a background state
  • [HSM-605] - Object reference error when the default system is offline
Known Issues:
v1.0.3 Release Notes
Published 2/12/19
Bugs fixed:
  • [HSM-385] App not respecting some timezone and clock configurations
  • [HSM-386] User is logged out when opening the app from the background even though Remember Me is checked
  • [HSM-488] Dashboards are lost when logging in with a username with different case letters
  • [HSM-492] Some right to left configurations are causing the app to crash
  • [HSM-494] App not sending users to the login screen when the session has expired
Known Issues
v1.0.2 Release Notes
Published 2/8/19
Bugs fixed:
  • [HSM-328] - Crash when a data adapter is disposed during an update notification
  • [HSM-331] - Crash when receiving updates from HS3 while switching dashboards
  • [HSM-332] - Application crashes when opening the Create/Edit Widget page with a null device bundle
  • [HSM-336] - Application crashes when resuming from a background state
  • [HSM-337] - Crash when editing a thermostat widget
  • [HSM-339] - Camera snapshot request stack is null when a task starts to download a snapshot
  • [HSM-348] - App crashes when editing a widget that does not have a valid reference
  • [HSM-349] - Crash on the device list when trying to update a specific device while the whole list is being refreshed
  • [HSM-353] - Crash while renaming a dashboard
  • [HSM-356] - Unable to load the device list because of a slider range value offset
  • [HSM-357] - Some network calls are orphaned on older OS versions
  • [HSM-358] - Navigation header gradient is reversed
Known Issues
v1.0.1 Release Notes
Published 2/5/19
  • Increased the resolution of the HomeSeer logo to mitigate blur caused when scaling it to fit larger screens
  • Improved the stability of the dashboard page
Known Issues:
  • Scrolling while dragging to move a widget is not yet supported
  • Images are slow to load on some older devices
  • Landscape orientation is not yet supported on the camera details page
v1.0 Release Notes
  • 2/1/19: Initial release
Known Issues:
