KeySummary
HS-961
Status/Graphics range options are always blank
HS-806
Hamburger menu cuts off last menu item on mobile
HS-1012
Some plugins are not shutting down when application is shut down
HS-1028
Copying a device with features in bulk edit makes incorrect copies
HS-1024
Unable to save log to flash on ZeeS2/Pi Hub
HS-1023
Mobile hamburger menu font is too small
HS-1033
Font on room/floor dialog not the same size for grid view and list view
Windows Installer, or simply restart HS4 and the update will be downloaded.
https://homeseer.com/updates4/SetupHS4_4_1_9_0.msi
For Zee S2/PI and SEL/PLUS update through setup
For standard Linux tar file:
https://homeseer.com/updates4/linux_4_1_9_0.tar.gz
