MyHS is a free cloud service that will allow you to access your HomeTroller or custom HS4 installation from anywhere using a browser-enabled device, HomeSeer Mobile, or our HS3Touch app with Designer. The instructions below will walk you through the process of creating your MyHS account.
Your MyHS account has now been created and your HomeSeer system can be accessed any time at myhs.homeseer.com or in the HomeSeer Mobile app! For information on setting up HomeSeer Mobile with your MyHS account, click here, for setting up HS Touch with your MyHS account, visit here.
After creating your account on myhs.homeseer.com, you will want to connect to your HS4 system. After connecting, navigate to Setup, then click on the Users tab. There should already be an account here with the MyHS credentials created above. If this account has not been created, enter your MyHS user name and password in the appropriate fields and click Add. This account should also have Admin and Local enabled under the User Type column.
