Instructions on connecting to your system via HSTouch through MyHS.
Configuring HSTouch Mobile App with MyHS
Unless you have HSTouch Designer and have created a custom interface, you will want to use our new app, HomeSeer Mobile instead.
On Android
  1. Download and install the HSTouch mobile app from the Google Play store.
  2. Launch HS3Touch and choose Settings from the three dot ( ⋮ ) menu.
  3. Tap MyHS and enter your MyHS username and password.
  4. Launch HS3Touch and choose MyHS if prompted to select a connection method.
On iOS
  1. Download and install the HS3Touch mobile app from the Apple App store.
  2. Access the Settings app in your device and open the HS3Touch settings.
  3. Tap MyHS, then enter your username and password.
