KeySummary
HS-1110
Event actions and triggers are saving the plugin NAME instead of ID
HS-1135
HsDevice and HsFeature retrieved from HS have a non-empty Changes dictionary
HS-1130
GetFirstLocationList and GetSecondLocationList don't work
HS-1129
HsApplication.GetAllDevices() throws an exception if one device or feature is badly configured
HS-1111
"Play a Sound" Event Action changes file extension to .wav over time
HS-1120
Scripts cannot access new IHSController API
HS-1134
Immediate command converted to a run script action after restart
HS-1047
Status Graphics Labels not working for ranges
HS-1006
Combine SEL and Standard Linux to a single build. Linux builds can now be updated through Setup.
HS-1115
Play sound not keeping order of clients, unable to enter manual client, action summary missing selected clients
HS-1119
Updated code that generates device status
HS-1131
Remove "Service Version: NO_VERSION" in exception thrown from HSCF
Plugin SDK updated to 1.2.3, release notes are here:
https://homeseer.github.io/Plugin-SDK-Docs/release_notes/pluginsdk_releasenotes_1_2_3_0.html
Windows Installer, or simply restart HS4 and the update will be downloaded.
https://homeseer.com/updates4/SetupHS4_4_1_14_0.msi
For Zee S2/PI and SEL/PLUS update through setup
For standard Linux tar file:
https://homeseer.com/updates4/linux_4_1_14_0.tar.gz
