Information regarding Settings for the Z-Wave UI plugin. |
The settings page of the Z-Wave UI allows you to modify the menu options to show your options and layouts that may be more familiar for some users.
Below are basic options available to the Z-Wave UI plugin. Be sure to click Save after making any changes
This option shows the current Z-Wave interface being targeted by the Z-Wave UI plugin and it's status of whether it is enabled or disabled.
Show Legacy Z-Wave Menu
Enabling this option will add the old Z-Wave menu options to the new Z-Wave menu giving you both options to use.
Disabled (default) | Enabled |
Show Legacy Z-Wave Device Config Page
Enabling this option will force the Z-Wave Device Config page to use the HS3 layout for Z-Wave device configuration pages. When disabled the option will use the HS4 layout and design standards. You will need to enable this setting to have access to Polling.
Clicking Manage will bring you to the HS3 layout of device config (deviceutility)
